Water meters
Dave Bush
Member Posts: 155
If so, what type of meter are you using, and where are you purchasing these things.
A Google search turns up pages and pages of ultra-high tech metering devices for just about every imaginable fluid, to connect to building automation systems and such, but I'm having a tough time finding a simple, analog meter that doesn't cost as much as the burner.
Any ideas?
Also, if anyone knows of links to a good, portable flowmeter for water, that can be installed/removed from water lines with unions, that info would also be appreciated.
Thanks in advance,
Dave
Any ideas?
Thanks in advance,
Dave
www.Istec-corp.com , they sell water meters , use the hitemp models0 -
Thank you, C.T.
That's more along the lines of what I had in mind.0 -
water meters
We prefer the Hydrolevel VXT. It's the best feeder digital water meter combination we've seen.
we use
a simple cold water mter by sensus or neptune. Check with your city water dept to see what they use. They are usually quite inexpensive.0 -
VXT Hydrolevel
If you are using an automatic feeder then just get the VXT. Its made for this application and wires in easily with the lwco.0 -
Well,
It never occured to me that the hydrolevel VXT had the meter built in.
Bad habit-keep on using the 101 because I've ALWAYS DONE THAT.
Thanks for pointing out the VXT. That's what we'll use next time.0 -
I know
Sometimes these things are right in front of us and it takes another set of eyes to "see" it. I think you'll like this device. Keep in mind that the display is reading feed cycles NOT gallons. Good luck, Todd0 -
I appreciate the info.
I just looked at their site, and found them in one of my wholesaler's price lists, adn it's cheaper than the 101A, so, it's kind of a no-brainer.
Thanks again, Todd, and everyone for the help.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
