Taco Or Argo
Argo or Taco for three zones
  • todd s
    todd s Member Posts: 212
    zone valve panels
    I've used both and I lean toward the taco. I like the ease of adding in a reset control and the timer for domestic priority. I also like the smooth cover for using labels or company stickers. Both brands have worked equally reliable for us.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    without....
    a doubt! TACO. Cleaner and much easier to read. kpc
  • Phil_6
    Phil_6 Member Posts: 210
    we use them both
    I lean toward the Taco, but they work equally well for us
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    The Honeywell R8889 series...
    controls up 3 or four zone valves, provides hot water priority, and can be ganged together for up to 16 zones. Works with Honeywell or Taco valves, compatible with any thermostat.. Available from any Honeywell distributor. Check it out at http;//hbctechlit.honeywell.com. Just type in the R8889, no charge and no password required.
  • Joe Mattiello
    Joe Mattiello Member Posts: 737
    go with Popular opinion
    you can't go wrong
    Taco, Inc.
    Joe Mattiello
    Technical Service Technician
    joemat@taco-hvac.com
    401-942-8000 X 484
    www.taco-hvac.com
    Joe Mattiello
    Taco Comfort Solutions
  • steve_6
    steve_6 Member Posts: 243
    I've used both and like taco
    Simple, neat, easy to read, easy to install. Organized very well
