Taco Or Argo
John R Leny
Member Posts: 14
Argo or Taco for three zones
zone valve panels
I've used both and I lean toward the taco. I like the ease of adding in a reset control and the timer for domestic priority. I also like the smooth cover for using labels or company stickers. Both brands have worked equally reliable for us.0 -
without....
a doubt! TACO. Cleaner and much easier to read. kpc
we use them both
I lean toward the Taco, but they work equally well for us0 -
The Honeywell R8889 series...
controls up 3 or four zone valves, provides hot water priority, and can be ganged together for up to 16 zones. Works with Honeywell or Taco valves, compatible with any thermostat.. Available from any Honeywell distributor. Check it out at http;//hbctechlit.honeywell.com. Just type in the R8889, no charge and no password required.0 -
go with Popular opinion
you can't go wrong
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
I've used both and like taco
Simple, neat, easy to read, easy to install. Organized very well0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
