Most Efficient Hot water heating boiler
Due to increased fuel cost I'm thinking of swapping out my Crown ABF-175 for a more economical way of heating my house. I have also a 65 gallon water maker off one zone. Any input from the crowd.
Ron
  • KCA_2
    KCA_2 Member Posts: 308
    Efficiancy?
    Any manufacturer that create an efficiant boiler takes for granted that the system is designed as efficiantly.
    f you install a 90% efficiant boiler but the system demands that it cycle every 5 minutes for 30 seconds then the overall efficiancy may be 50%.. At sea level of course.. Up here in Colorado we facture in the lack of Oxy. At least thats my excuse.
    sO.. tO SAVE MONEY, PUT IN A STANDARD 80+ EFFICIANT BOILER AND A 90% EFFICIANT SYSTEM DESIGN.
    oops.. Hit the caps.. sorry
    :-) Ken
    :-) Ken
  • DrV
    DrV Member Posts: 6
    Use a modern tankless oil/gas water heater. Electric is also a possibility in places like Minnesota that offer duel-fuel rates or Long Island, NY that offer lower all-electric heating rates. The do-it-yourself system I have been using since 1996 is illustrated @ http://gfxtechnology.com/combi.html & http://gfxtechnology.com/Combis.PDF.
    Modern tankless "boilers" are self modulating. Mine has a remote controlled set-point that eliminates cycling-loss. On cold days, the water temperature goes up to 180F. On warmer days it's lowered to 135F, so the circulators run almost 24 hours.
  • Paul Pollets
    Paul Pollets Member Posts: 3,666
    Viessmann
    I'd be uing a Viessmann Vitola boiler with Chassis Burner, Vitotronic 200 control for oil fired systems or the Vitodens 200 wall-hung if using gas. Their VitoCell stainless indirect DHW tanks are the best in the Biz...hands down. Yes, they cost more. It's worth it.
  • Leo G_99
    Leo G_99 Member Posts: 223
    just make sure
    that the tankless, if you go that way, is rated for heating. As 2 families were killed in Ontario about 4-5 years ago, by having tankless water heaters installed as house heating systems.
    Leo G
  • Tom_53
    Tom_53 Member Posts: 43
    Leo G
    Can you explain what happened?
    Tom
  • Constantin
    Constantin Member Posts: 3,796
    The Vitola and Vitocell is a great oil combo
    Thus far, I'm quite impressed with both. The Vitola cannot be thermally shocked by design and is flue-gas condensation-proof as well. Unlike its competitors, it achieves this through an innovative bi-ferral HX instead of variable-speed injection pumping and the like. The result is very low electrical energy consumption.
    The distribution and control system is another area where you can save a lot of fuel and increase performance at the same time. The Vitotronic 200 can take care of outdoor reset, internal calls for heat, a motorized 3-way or a 4-way valve, etc. in a highly-integrated manner.
    It's a true plug-and-play boiler... If the pre-numbered plug doesn't fit, you're probably trying to stick it into the wrong place... I also like the innovative features like the option to measure the flue stack temperature and alerting me to potential sooting if the stack temperature goes up.
    The Vitocell 300 tanks are certainly quite expensive, but should last forever. Their large inspection port makes cleaning them out a comparative breeze. to the best of my limited knowledge, the horizontal model is the only one in this country rated to make hot water from steam. However, you do pay for these features dearly.
    Lastly, I like that the US headquarters is an hour away in RI. I can plead with Ed and Jim in person if I need a part.
  • DrV
    DrV Member Posts: 6
    Just make sure ...
    Rinnai makes outdoor tankless gas water heaters, which are popular in earthquake-prone Japan -- not in North America.
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    If its the one I'm thinking of...
    The tankles is generally designed to operate at full burn, establishing and maintaining a good draft to get rid of flue products. The tankless in question was running at minimal burn, and lost its draft, and consequently started dumping products of combustion into the home. It is possible that ANY modulating appliance that is running at minimal burn can have its draft overcome by something as small and simple as a bathroom exhaust fan.
    This is why its important to test for draw under all conditons in the combustion zone.
    ME
  • Leo G_99
    Yup
    that's what I remember also. The saddest part was that 2 families were killed within a short time of each other by this set-up.
    Leo G
