Natural gas power burner for oil fired steam boiler
Ryan_6
Ryan_6 Member Posts: 3
Went to a no heat call and found the blower motor on a power burner locked up , and of course the motor was red hot . Right now this guy is with out any heat and I am not sure where I can get parts and / or a complete unit . Its an old steam boiler with doors to burn coal and the oil burner was removed and a power burner was put in . This is freezing and need your help guys , Thanks
  • Ryan what kind of
    power burner is it? Need to know that and also what is usually the easiest thing to do if it has a slip in tray is install a brand new tray.
  • Ryan_6
    Fixed it
    I found out that it is a wayne power burner and connely supply had the fan assembly in stock . Worked out well but thanks for helping .
