cycle rate adjustment
Ray_2
Member Posts: 21
I have a Honeywell ct300 thermostat- and 1 pipe steam system. Do I set The thermostat as "Gravity air / water" or "Hot Water"?
I have a Honeywell ct3400 thermostat- and 1 pipe steam system. Do I set The thermostat as "Gravity air / water" or "Hot Water"?0 -
If your system uses circulators, it is not a gravity system.
Edit: I am sorry, I didn't notice you had a steam system. But then, why are you choosing between two "water" options? That's what misled me. Isn't there a "steam" setting?0 -
thermostat setting
I'm not familiar with circulators- how would I know I my system had one?0 -
Gravity setting
Remopve the thermostat from the subbase, find the screws labeled 1A & 1B, turn each one of these screws out one full turn.
Here's a link to a pdf fill of the manual for the CT3400. Refer to page 18 & 19 for more instructions/pictures.
http://hbctechlit.honeywell.com/techlit/PDF/69-0000s/69-0733.pdf0 -
Mr. Kalia
Please reread his post, he did say he had one pipe steam.0 -
Don't worry about it Ray,
If you have steam you don't have circulators.0 -
Thanks
I just wanted to be sure 1 pipe steam was considered a gravity system
Thanks again0
