cycle rate adjustment
Ray_2
Ray_2 Member Posts: 21
I have a Honeywell ct300 thermostat- and 1 pipe steam system. Do I set The thermostat as "Gravity air / water" or "Hot Water"?
  • Ray_2
    I have a Honeywell ct3400 thermostat- and 1 pipe steam system. Do I set The thermostat as "Gravity air / water" or "Hot Water"?
  • Chuckles_3
    Chuckles_3 Member Posts: 110
    If your system uses circulators, it is not a gravity system.
    Edit: I am sorry, I didn't notice you had a steam system. But then, why are you choosing between two "water" options? That's what misled me. Isn't there a "steam" setting?
  • Ray_2
    thermostat setting
    I'm not familiar with circulators- how would I know I my system had one?
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Gravity setting
    Remopve the thermostat from the subbase, find the screws labeled 1A & 1B, turn each one of these screws out one full turn.
    Here's a link to a pdf fill of the manual for the CT3400. Refer to page 18 & 19 for more instructions/pictures.
    http://hbctechlit.honeywell.com/techlit/PDF/69-0000s/69-0733.pdf
  • Glenn Harrison_2
    Mr. Kalia
    Please reread his post, he did say he had one pipe steam.
  • Glenn Harrison_2
    Don't worry about it Ray,
    If you have steam you don't have circulators.
  • Ray_2
    Thanks
    I just wanted to be sure 1 pipe steam was considered a gravity system
    Thanks again
