Anticipated Snow Levels
a relyable recource to determine the "anticipated snow levels" in various regions throughout the world. I'm about Googled out!
Thanks in advance.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks in advance.
Try Weather Underground
Replace "12345" with your zip.
http://www.weatherunderground.com/cgi-bin/findweather/getForecast?query=12345#History
Then, scroll down to "history and almanac". There's a link to "seasonal weather averages". Should tell you what you want.
or, there's always the noaa..
http://www.ncdc.noaa.gov/oa/climate/research/snow/historical.html0 -
crystal ball!0 -
I'm afraid you misunderstood the question. To figure out how high to put a vent, you need the highest likely LEVEL of standing snow cover, not the daily/weekly/monthly snowfall amounts. The two things are not the same.
As far as I know, no records are kept of snow cover depth, except in ski areas and such. The number towns use for vent placement is just a guesstimate plus a safety margin. Maybe it is OK to use the record snowfall level plus 6" for safety. Or a crystal ball...0 -
Try...
... ASHRAE. I just looked up some info on that very subject in my old 1991 "HVAC Applications" for a snowmelt project.0 -
How much do you expect?
This information should be available to ALL local agencies as sometimes the inspectors (local) don't know where to look for this specific information. Furthermore, without a defined snow level within a township this could be a major conflict.
Who knows?0
