Condensation on Windows
Bill_49
Member Posts: 25
Condensation on Windows, What does it indicate.
Condensation
Generally means either too much humidity or Carbon Monoxide0 -
If it's a steam system ...
The air vent on the radiator(s) are blown or a system leak is nearby.
Unless of course, it is Wednesday night, pasta night and you're having spaghetti for dinner?
Condensation on windows
It can indicate many things:
Crappy windows with a low thermal resistance.
Too high an indoor humidity (explore causes: cooking, laundry dryer vent leaking, too many plants, too many showers/inadequate bathroom exhaust, high activity level from occupants, leaking flues from fuel fired equipment, leaking steam pipes or condensate pipes in a steam heating system....etc. )
Indoor air temperature being maintained very warm (warm air has higher capacity to carry moisture/humidity, so the warmer the air, the more ambient humidity there can be), combined with the crappy windows.0 -
I was just thinking about you...*~/:)
I saw a book cover some where that hadnt been released at the time ,it seemed fairly comprehensive and was wondering...is there a small book list of ten or so books that you feel incapsulates the geo thermal designe and space conditioning field...i would like to further my strength with in this realm....thanks .I knew you'd understand.0 -
crappy windows
Hey! Some of those crappy windows are beautiful! But they still would deserve a good storm window.
Sustained condensation on windows will also mean condensation elsewhere in the structure that could do long term damage.
But my real concern here is blocked venting of the boiler or water heater. This is a real health concern, to say the least.
Any critters building something in the chimney?0 -
Condensation
See the thread titled "Furnace shut down from CO. It addresses comprehensively on this very subject. Please read it. Condensation may very well be caused by a blocked flue, vent or chimney. The result will be high levels of carbon monoxide inside the building. Do not run the furnace, boiler, water heater, fireplace, dryer, etc. Ventilate the building and run, don't walk to the phone to call a professional to have it checked immediately.0 -
I live in an old colonial house. The windows on the first floor
have no condensation. However, some on the
second floor have ice (I assume from condenstion) on the inside of storms, while the old wood frame 8 pane glass windows have only a little condensation.
Why would the second floor windows have condenstion while
the first floor has none?
JC0 -
terrarium
The second floor is more prone to condensation for several reasons:
Heat rises, carrying with it water vapor.
Bedrooms are on the second floor. Respiration of slumbering people for 8 hours at stretch really does add up.
Bath is usually on second floor.
As far as condensation on the storm windows, this means that the storm window seals more tightly than the interior window. Moisture cools and condenses on the storm glass. I'll bet the weep holes on the storm windows are blocked with paint or debris.
This may also explain why the downstairs storms don't condense much. The storms may have clear weep holes or the wear on the interior windows may be less allowing for a tighter seal on the interior window. (bedroom windows seem to get the most use)0 -
hot date
one way to tell
If you have a central chimney in your home and that wall covering ( drywall or plaster)is damp then you know the chimney is blocked.0 -
Condesation on windows may also mean lack of air infiltration.
You may need a HRV mechanical system if the home is new construction.Jeffrey0 -
Jeff-- Condensation on the storm window indicates that the prime window is not tight-- ( typical in an older home). There are two possible solutions-- 1. Tighten up the prime windows with weatherstriiping-- vinyl bulb @ the meeting rail and spring bronze @ the window tracks. I have also heard of people drilling a tiny hole @ the top of the storm to act as a weep hole and allow the moisture to dissipate. This will not affect the performance of the storm.0 -
Bad news
It means you need to get a Mac. : -)0 -
Condensation
Also read the thread titled "Home Depot Gives Advice." It is eye opening reading.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
