Radiators arent getting heat!
B Cohen
Member Posts: 18
The boiler is working. Risers are hot. No radiators at all in the building get hot. Its a one pipe system. Main air vent in front of building only. All radiators have been removed to check for blockages, and air vents are new. Raditor shut off valves have been removed also and even though the riser is hot no steam moves toward the radiator.
I already, cleaned out return lines, all controls on boiler is new. Any suggestions or help would be gratly appreciated. Thanks.
Radiators arent getting any heat
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
