Boiler water temp
M Ransley
M Ransley Member Posts: 45
Several questions, I have a 3 story house with basement and my old and new Weil McLain say 12lb cold , is this normal of most units with pump and big radiators.
Second 185 is not heating it , radiators are bled but can raising temp to 200-210- be bad as it is under 12lb cold psi , boiling temp- is much higher than 212 @ higher pressures, Boiler pressure starts at 12 and goes to 20 at 185
  • Weezbo
    Weezbo Member Posts: 6,231
    You need some help. try find a professional ....
    it sorta defys words.
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    220* will get you there --no don't do it // you have some other problems --what's your --delta "T"
  • Empire_2
    Empire_2 Member Posts: 2,340
    New Boiler/New pump
    I think what you will find is that you may have a flow problem. Since the house is old and the pipes are probably large, 2-3",.... Water is moving, slow at best. May require a different pump. Call A Pro who can determine the actual head and flow rate required for this system. Thats the only way to be sure.
