Boiler water temp
M Ransley
Member Posts: 45
Several questions, I have a 3 story house with basement and my old and new Weil McLain say 12lb cold , is this normal of most units with pump and big radiators.
Second 185 is not heating it , radiators are bled but can raising temp to 200-210- be bad as it is under 12lb cold psi , boiling temp- is much higher than 212 @ higher pressures, Boiler pressure starts at 12 and goes to 20 at 185
You need some help. try find a professional ....
it sorta defys words.0 -
220* will get you there --no don't do it // you have some other problems --what's your --delta "T"0 -
New Boiler/New pump
I think what you will find is that you may have a flow problem. Since the house is old and the pipes are probably large, 2-3",.... Water is moving, slow at best. May require a different pump. Call A Pro who can determine the actual head and flow rate required for this system. Thats the only way to be sure.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
