Turning off radiators
Jennifer_4
Member Posts: 2
Just moved into a house with oil/steam heat. We have our x-mas tree in the front window and want to stop heat flow to that radiator... is there any safe way to do this? Thanks!
Assuming it's still functional...
You should have a hand valve on the radiator that you can close to turn off the radiator. Hopefully, it is still functional and not stuck in the "open" position.
I have attached a picture of the valve. You will probably want to wait for the radiator to be cool. This not only makes it easier to work on, but should allow you to seat the valve better.
Make sure you always keep this valve all the way open or all the way closed if you have a single pipe system. It's an on/off switch, not a throttle.0 -
In case the valves are old and you are concerned with them sticking closed or open, you can turn your air vent upside down. The radiator certainly won't heat.
You may need to take it off and put some teflon tape on the threads when you are ready to turn it back on.0 -
What about...
I have a similar question about my 3rd floor radiators. We hardly ever use the third floor and it gets awful warm up there anyway. Would shutting off those rads mess up the system?
Thanks,
Paul0 -
As you see above, people have given instructions on how to turn off steam radiators. If doing this would "mess up the system", they would not have given these instructions, right?0 -
I guess not
I just wasn't sure if shutting off an entire floor would have a different effect on the system than just shutting off one rad as the initial poster had asked.
-paul0 -
curious rookie
I am curious about this as well.
That would make your boiler 'over-sized'. That could create a problem.
What would the symptoms be, though?0 -
Thanks for your help! Unfortunately I can find no such valve on the radiators and think maybe it's under the floor? Could I do something with the rad key?0 -
If its one pipe steam...
you could jury rig something to close off the air vent and it won't get nearly as hot as it would if the vent were open...
ME0 -
Could you post a picture of the radiator
This board makes it pretty easy to upload a picture. If you have a digital camera you might want to post a picture of the whole radiator.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
