oil boiler shuts off at night
Karl Christeleit
Member Posts: 1
My oil fired boiler shuts off at night for no reason. I just had it cleaned and serviced and it continues to shut off. It will fire right away when I hit the reset button. can anyone assist!
call a pro
You should call your oil co service dept .I service oil and it could be a few things like loose wire connection or a dead spot on your burner motor to high vacume on your oil supply line .Just have your oil co come by and chk it out might just be some thing minor usually is good luck peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
oil burner shutting off
I agree with clammy call your oil co.0 -
And if they can't fix it
switch to a company that can.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Find someone who does the work right.
oh it was cleaned just last week. , yesterday, two days ago....seldom very seldom was it as clean as the owner Belived.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
