Re-pipe - DF
Dan Foley
Member Posts: 1,268
Here is the "before" photo:
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=305&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
After...
Here are the "after" photos:
Nice
Nice work,Dan.
Sure does make it look alot cleaner and neater!0 -
John,
It was nice to catch up with you in Orlando. Were you able to check out the builders show? -DF
I gotta say
Someone put an awful amount of time into the job , looking at the before pic . Your really did streamline the system Dan . What was the reason behind the repipe ?0 -
Re-pipe
Hi Ron,
This one was on me. It was a job that was done just as I was leaving my previous employer 3 years ago. It was poorly designed (by me) and poorly executed due to a lack of oversight (again, on me).
We had lots of problems balancing the system and getting the proper flow rate to the remote manifolds. The performance of the indirect (or lack thereof) was also disappointing. After numerous service calls, the homeowner finally exclaimed "I wish I had just installed forced air!" Those words stung and we finally took responsibilty and made it right - on my dime.
The lesson learned: Finish what you got before you start something new. The good news is that the system works great now and the homeowner loves her radiant/DHW system and is also my best advertiser in her neighborhood. She got me two new jobs in her neighborhood in the past three months. -DF
Central , to the install are service questions....
maybe , being able at a central location to remove and replace parts, trouble shoot make adjustments and repair and protect components these cabinets are good things...buh what are you going to do with all that extra daylight ..?0 -
'Tip of the hat to you
That was a very ethical thing of you to do, considering you could have just walked away.
The previous manifold is impressive to say the least. Whoever soldered it all up did a nice job... But if it doesn't perform... out it goes. Economists refer to this as "sunk cost!".
Anyway, congrats again on the new installation. It looks super and I am so glad that your generosity has been repaid with extra jobs in the neighborhood. Good Karma comes around eventually and your reputation is usually your biggest business asset.
BTW, what pump-panel are you using there for distribution?0 -
Before photo
Besides the re pipe did you also change the boiler or is that the visseman with it's jacket off the piping on the before may not have work but it all looks on the plumb and square neat excellent pipe work .On that after photo that,s some real slim lining on the piping looks
great !I also think your a true craftmans and a fine human for addmiting your short sight with the original system and went back and hookem up correctly you my friend must have some good karma .Again great work give yourself 2 ataboys and a pat on the back .Peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Panel
Constantin,
Thanks for the nice comments. It did feel good when we started this one up and everthything worked as planned.
The panel is a 311-V Pro-Panel by Wirsbo. -DF
Boiler
Thanks, Clammy. The boiler stayed and it is a Monitor MZ40. The "after" photo shows the same boiler with the jacket installed. -DF
DF - DFW
Dan Foley - Does Fine Work.0 -
It takes a big man...
to admit when he's wrong.
It takes an even BIGGER man to fix it on his own dime, especially when he didn't profit from the job in the first place...
You stand extremely tall in my mind.
Honesty pays.
Keep up the great, ethical work!
ME0 -
DF..
Mark nailed it. Great job!..Robert O'Connor/NJ0 -
Mark and Robert,
Thanks for the nice comments. It made my day! -DF
Dan
It's a shame there are not more of you in our industry!!!!
Not many businesses would do what you did, but look at the end result! 2 more jobs.... + great word of mouth for you and Radiant Heating!
Keep up the great work Dan!
bb0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
