Venta Air washer
Ted_9
Member Posts: 1,718
Anyone here use it. Are they good? Low maintenance?
PATRIOT HEATING & COOLING, INC.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=343&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Venta Airwasher
I bought a little one. It won't get a bedroom above 35% RH, but this is about right. I have no way to tell if it's cleaning the air, but if it is, this is the best way to do it.
High quality, but costs three times what a more conventional filter pad unit costs. They also clean the air, but the media needs replacing.
The airwasher needs water additive every couple of weeks. It just doesn't humidify well without the additive. Water must be manually replaced, so it's not low maintenance per se.There was an error rendering this rich post.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
