Use PEX to retrofit one pipe steam to water
Steve Garson
Steve Garson Member Posts: 191
I am converting a one-pipe steam system to hot water. Since there is 1-1/4-inch steel pipe feeding each radiator on the second floor, I was wondering is it is practical to feed a 3/4 or 1/2-inch PEX tube down the steam pipe to avoid cutting up the house to install new feeds. The ID of the pipe is 1.38", so there should be adequate room. Since each side of the house has two radiators, I could connect the two on the same floor, use the PEX as the feed and return, and potentially save lots of labor.
Has anyone done this before? Is there any reason I shouldn't do this, assuming that the PEX is not abraided much in the process?
