boiler pressure gain
Helgy_3
Helgy_3 Member Posts: 40
Happy New Year to everyone.....
Working on a 20yr. old Peerless hot water boiler. Problem is as the boiler heats up the pressure gain goes way up until the saftey pops. Setup is two story home all cast iron radiators. Each one having it's own air bleeder. Boiler has a rafter tank w/ tank valve. I filled the system bled the air from each radiator. Made sure I had air in rafter tank via tank valve bleeder. Starting pressure of about 14 lbs. Start system up and at about 140 degrees it's ready to blow it's safty valve. What am I missing here. Any help would be great..
Thanks, Helgy
