Steam Raditor Suppliers
Anna
Member Posts: 3
I believe someone posted the name of a supplier of radiators in NJ awhile back. I'm looking for a small steam raditor for my hallway that was removed years ago and would appreciate the name(s) of local suppliers in the NYC/NJ area.
I was also looking into the thin radiators that are installed flushed to the wall. Are they any good? I have an older home with very limited space in the hallway and was looking at all my options.
TIA
Annie
TIA
Annie
Radiators
Radiators come in many styles. There are steel panel radiators made by companies like Runtal, Buderus and DiaNorm. There are also cast iron radiators made by companies like Burnham. If you check the websites of these comanies they should direct you to a local distributor.0 -
Try www.steamradiators.com0
- 167 Indoor-Air Quality
