Warmboard job
JimmyJam
Member Posts: 78
We are starting a Warmboard project tomorrow and am looking for some answers please. Warmboard is closed for the holidays i guess. We are installing panels over vapor barrier/concrete slab and am wondering if we need to allow for any expansion of panels around perimeter and between panels or can we butt them tightly?
Thanks!
Thanks!
not a warmboard expert
Warmbaord is plywood, and you should do the same for that as a standard subfloor. Wood expands more by moisture content than heat. So unless the moisture content of the WB is much lower than expected operating moisture content, there should be no reason to include gaps.
jerry
