One I've not run into...........
S Ebels
S Ebels Member Posts: 2,322
Ancient Bard oil furnace with a (Wayne?) burner model MP-98. The motor is shot.... the problem is the motor flange on this old girl is about a 1/2" larger diameter than a normal burner motor.
Are these larger diameter motors still available? It's so rusted up I can't tell if it's 1725 or 3450 rpm. (this old babe has been doing yeoman's work in a dairy barn for 35 years) Obviously the motor numbers have also succumbed to brown rot or I would post them. There are no supply houses open at 11:30 PM so I can't call and find out. Therefore, I seek the knowledge of the WALL. Anyone awake yet?
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Check out ......
    The fuel pump numbers. If you can still read them, you'll get your answer.(unless it has been replaced by a dual speed competitors replacement) Best of luck. Chris
  • Weezbo
    Weezbo Member Posts: 6,231
    i am awake....its early *~/:)
    do you have the time to describe the coupling to the pump? i am inclined to think it is 1725 what pump does it have the numbers on it might say right hand rotation? i am not good at typing stuff:(
  • Tony_8
    Tony_8 Member Posts: 608
    I've seen them
    lots of 'em. probably threw most of them away. I'll check my bonepile today and see if I can glean some info for you. I'm sure it's 1725, too.
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    It's probably a 1725 rpm,
    N Mount, Carlin makes an awesome replacement motor.
    http://www.carlincombustion.com/products/pscmoter.htm
