Riello BF3 pump noise?
Ted_9
Ted_9 Member Posts: 1,718
Well this one on a BF3 makes a wining(spelling) noises. Any thoughts?
PATRIOT HEATING & COOLING, INC.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=343&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Weezbo
    Weezbo Member Posts: 6,231
    Yes...take a look at the supply and return lines....
    Riello likes the supply on the supply and the return on the return.(with a bypass in the return).
  • Ted_9
    This is a single pipe gravity fed set up.
    I still need someone to check the pump pressure now. It seems noisey.
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    Single pipe gravity
    should be like a mouse. Do you have loops on both ends of the line? Keep in mind they are required by code in MA. In FACT, everywhere! One of the most overlooked mistakes out there. You MUST provide for expansion and servicing. Beauty of it is it also quiets them down.
