Main Vent Location Question
I am a newbie. Just finished reading We Got Steam. Great book.
I have an older square boiler, one pipe system, 11 radiators. Two risers are on opposite sides of the boiler. One header feeds one set of radiators, the other, another set. They do not connect to each other. (Do I sound like an expert yet?)
I have 2 main vents. Each are located above the boiler and connected to the wet return line, where the wet return goes straight down and connects to the side of the boiler (harford loop?). Is this the correct placement for the vents? Is this the end of the run?
Another question. I would like to replace these vents. One is a Vent-Rite 36. The other is rust stained. What is a good replacement for these vents? Hoffman 45?
Thank you in advance.
