Oil Relay with alarm contacts???
Floyd_7
Member Posts: 136
Had a fellow call tonight that had a huge mess....the oil burner went out on reset and the upstairs shower valve froze.
Had a central alarm, but it didn't go off. Can I get a relay with alarm contacts that I can hook to the central alarm system to call him when the burner goes out on reset????
Thanks!!
Floyd
Thanks!!
Floyd
Floyd
The Honeywell R7184U has alarm contacts that can be wired into a visible or audible alarm as well as a phone dialer. Hope this helps. Here is a link to their tech site .pdf file on this control.
http://hbctechlit.honeywell.com/techlit/PDF/69-0000s/69-1233.pdf
Glenn Stanton
Manager of Training
Burnham Hydronics
www.burnham.com0 -
Thanks!!!
That will work!!!!
Floyd0 -
The Carlin line of
primary controls is another method.
The 7184 works well, but you can always just got to this:
http://www.onwatchinc.com/system32/spec.html0
