Parts for Automatic Burner Corp. Chicago, IL
Dave_51
Member Posts: 1
Sounds like ABC is out of business. I need a blower fan for a Model GO4000M Serial 41752. Anyone got one laying around?
1 Sounds like its time to sell them a new burner...
2 If you mesure the diameter of the fan and the width then figure out the rotation looking in the open end many fan sizes are available from a supply house.
3 Sounds like its time to sell them a new burner
Bought by SunRay of LI, NY who
was bought by Enerjet who was bought by Oertli, who...........
Da gone, bye-bye, new burner time!0 -
what oil pump is on that ? original Webster or upgraded Suntec anyway its an ABC Sunray --low efficiency to todays standards put on a new burner ---it will pay for itself in fuel savings--and take the next step and upgrade the system--which i'm sure will be less than a 7 year payback0 -
ABC
ABC has been gone for many years now. Westwood,Crown,Sid Harvey's and others have after market burner fans available that will probably fit perfectly. Take old one with you to the supply house for a match up. The advice for a new burner is sound. A new one will be so much more efficient.0 -
If that's a \"Golden Cup\" model
it is a flame-retention unit, so you can get decent efficiency out of it. I've been lucky in the past, but parts for these things are getting harder to find. If you can't find a fan for it, any current-model flame-retention burner of the proper size should work well.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
