Thermostat Recommendation
Mike T., Swampeast MO
Member Posts: 6,928
Yes, "Mr. Modulation" is asking about a digital t-stat and it's even for forced air.
Any recommendation for a programmable two-stage (heating) for forced air electric resistance?
Mike i think honewell has one that works fine.
Bills off on vacation however a while back some guy had put one on his boiler and was wondering what number to put it on for his radiant and decied honewell and the rst of us hadnt a clue and was going to use the highest number setting possible....which should with radiant allow it to bounce way up and way down
)). 0 -
Well, I am modulating
with a Honeywell Visionpro for flat panel rads. While I am using the single stage heat only, the model TH8320 VisionPRO supports 3 heat and 2 cool.
Either I am dreaming it or the visionpro is doing it, learning how fast the building heats in the morning. It seems that as it gets colder, the stat is turning the heat on earlier. Once it reaches the setpoint, it does not vary. I can hear the relay clicking but it displays 68* or whatever it is set. And I found it easy to program, pull it off the base and program sitting in the chair where you can read the manual if needed. I like my new VisionPro!
Attached is the manual for the TH83200
