Honeywell Thermostat:M# T6575B1003
Roy Tenn
Member Posts: 15
Hi All,
I would just like to know how you would wire this Tstat
so the fan cycles on and off with a call for heat or cool.
As it is now,when the tstat is on the fan runs cont. and the tstat cycles the valve. We do the maintenance and service of the building.The equipment used is a Enerzone Fan Coil Unit M#VFC350. The valve is a Honeywell (VU444A1007) actuator 120v,60Hz, 5w
Looking forward to your replies. Thanks in advance.
Roy
Roy
T6575...
That's a line voltage, digital fan-coil thermostat. There are a lot of models of that product, and it's from a different division than I work for, so I'm not that familair with that product line. Try http://hbctechlit.honeywell.com, and type in the part number, and follow the prompts for a tech sheet. That site is free, no password required. You also can call 1-800 468 1502 for the contractor tech hotline. Sorry I couldn't help more.0 -
Thanks Bill. I will try that site and tech hotline.
Have a safe Merry Christmas and a Happy New Year to
you and your family.
Roy0
- 167 Indoor-Air Quality
