Tour Anderson Controls
Ken D.
Member Posts: 836
To the previous post. That display module is obsolete and is no longer available. I checked our stock and found none of the old modules. Unless you can find one otherwise, you will need to update control. The TA Xenta is compatable.
Tour Anderson Controls.
To the previous post. That display module is obsolete and is no longer available. I checked our stock and found none of the old modules. Unless you can find one otherwise, you will need to update control. The TA Xenta is compatable.0
