Thermal Expansion Tanks
Uni R
Member Posts: 663
For example is the Watts ETX worth the extra money over the ET? Are there any other tanks that seem way better than the others?
one tank 2 uses
On my truck I carry an exp. tank for a domestic water heater. Should I need a exp. tank for hot water heating app. I adjust the nitrogen charge as needed. Best Wishes J.Lockard0 -
the rubber on high pressure one may be thicker
cause the heating one, looses a pound of pressure each year, - maybe the hot water high pressure one, holds it correctly for years0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
