Pressure regulator
Paul_28
Member Posts: 113
The best Pressure Regulator to reduce street pressure.
Watts0 -
So many
There are so many Watts regulators, which one to choose0 -
I like
the honeywell - Braukman one. I think the watts # is a U-5-B0 -
Watts
For residential applications I use Watts 25AUB-Z3 regulator. Has a built in by-pass to allow for water heater thermal expansion. http://www.wattsreg.com/default.htm
(anyone know how to make web addresses show up as links?)
JimThere was an error rendering this rich post.
Courtesy of Alan M & Glenn Harrison
Jim, it's done by using HTML Code. The code is just below for you to view. If you would like to turn it into a link just put a space between the a & href and put one of these < before the a and this < /a > after your company here
ahref="http://www.climatecadvanced.com">The Name of your company here
Once you put the space it should look like this
You could do this where you store your personal settings or just type it when you wish to use it.
Is it spring yet? Man has this been some winter!
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk
In case you can't follow Alan's post, here's the HTML command, a little bit clearer I hope ...
Link to Heatinghelp.com
Which will end up looking like this ...
... in the finished product.
Obviously, change the document reference to your own web page instead of www.heatinghelp.com, and the text which says "Link to Heatinghelp.com" could be any other message.
The target="_blank" element tells the browser to open the linked page in a new window, rather than replacing the page you're currently viewing.
Lastly, at any time the folks at invision.net that host this forum could choose to disable this functionality. It can be a bit dangerous since a malicious user could embed other nasty stuff.
Ditto....
On the Watts 25AUB
Murph'
PRV
Watts 25 AUB.Nice feature the thermal expansion device,for a little more peace of mind, still like to ad seperate exp tank @ H.W.H.Helps me sleep.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
