How do I find a steam leak that I can't see?
JC from PA
Member Posts: 16
I have a steam leak in a building. I'm assuming this becuase of the high humidity in the air. I've checked all the piping that's exposed and can't find it. Should I isolate and fill the system with water?
That would work
but have a couple of helpers with you to spot the leak, and be prepared to instantly dump the water out when you find it!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
you will probably
ruin the vents they are not meant for city pressure0
