ratiator heating to baseboard heating.
Hi. My Livingroom is 12 by 12 by 12 high. I have radiator heating. I have remodeled my livingroom; insulated my outer walls. My question is as follows: Would I benefit by taking the radiator out and replacing it with baseboard heating going along two walls sort of like an "L" along the two walls at about 9 feet long each baseboard?
Thank you in advance for you healp and answer to my question........Oscar Garzon
  • Oscar Garzon
    Oscar Garzon Member Posts: 2
    radiator heating to baseboard heating.
    Thank you in advance for your help and answer to my question........Oscar Garzon.
  • Ted_9
    Ted_9 Member Posts: 1,718
    If the new area is on its own zone then baseboard would be fine. You could also keep the old rad and put it on its own zone too. If it is controled from the main house zone, then I would stick with the cast iron.
    PATRIOT HEATING & COOLING, INC.
