Anyone make a powervent steamer over 175,000....Boilerpro
Boilerpro_3
Boilerpro_3 Member Posts: 1,231
Burnhams PIN series goes to 175,000 input, anybody make one bigger for gas? Chimney is shot and I would like to go out the wall without customizing a Tjernlund.
Thanks all
Boilerpro
  • RoosterBoy
    RoosterBoy Member Posts: 459
    yes http://www.fieldcontrols.com
    swg-5s get the stainless steel it lasts allot longer and looks better dose not cost much more
    also you can call them and ask
    FIELD CONTROLS, LLC
    2630 Aiport Road
    Kinston, NC 28504
    Tel: 252.522.3031
    Fax: 252.522.0214
    thanks
    here is what it looks like
  • Boilerpro_3
    Thanks, I'll keep that in mind, however,
    I am looking for a factory powervent steam boiler like the Burnham PINPV series only bigger.
    Boilerpro
  • Dale
    Dale Member Posts: 1,317
    Tjernlund
    www.tjernlund.com I don't think there's a power vent sidewall unit any bigger than the one you mentioned and I doubt there's enough of a market for one. And, since that would be positive pressure catagory 3 venting the stainless vent material at larger sizes would probably be as expensive as a Field or Tjernland. Another benefit is the fan noise away from the boiler.
