Munchkin T80
Ted_9
Member Posts: 1,718
Just started one up last night with vision one. When I check the outdoor temp itsays NC. Everything is hookied up and I went through the programming.
Any ideas?
PATRIOT HEATING & COOLING, INC.
Any ideas?
Couple of things to check
I sometimes do not strip enough wire when I connect the OD sensor. Take a look there to make sure you haven't pushed the wires in too far to make contact.
Make sure your connections on the board are good. Once those posts are pushed in, they shouldn't come back out.
My guess is that the wires to the OD sensor are not making contact.
Mark H
Munchkin
Ted,
We here at HTP have answers. If you had called us from the site , we would have been able to have you up and running on outdoor reset in no time.
Give me a call. 800-323-9651 ext. 157
Guy0 -
Update:
Chuck from HTP stopped by the job(very local to HTP) and found the problem....
It was me. I installed the outdoor sensor wire on the wrong molex plug. The same two spots were open on the newer set up.
Thank you HTP and especially Chuck for coming by to check this out.
PATRIOT HEATING & COOLING, INC.0 -
Ted,
I am glad I was able to help,
Now you have post the photos!!!!!
Chuck0
- 167 Indoor-Air Quality
