Anyone make a powervent steamer over 175,000....Boilerpro
Boilerpro_3
Member Posts: 1,231
Burnhams PIN series goes to 175,000 input, anybody make one bigger for gas? Chimney is shot and I would like to go out the wall without customizing a Tjernlund.
Thanks all
Boilerpro
Thanks all
Boilerpro
yes http://www.fieldcontrols.com
swg-5s get the stainless steel it lasts allot longer and looks better dose not cost much more
also you can call them and ask
FIELD CONTROLS, LLC
2630 Aiport Road
Kinston, NC 28504
Tel: 252.522.3031
Fax: 252.522.0214
thanks
here is what it looks like0 -
Thanks, I'll keep that in mind, however,
I am looking for a factory powervent steam boiler like the Burnham PINPV series only bigger.
Boilerpro0 -
Tjernlund
www.tjernlund.com I don't think there's a power vent sidewall unit any bigger than the one you mentioned and I doubt there's enough of a market for one. And, since that would be positive pressure catagory 3 venting the stainless vent material at larger sizes would probably be as expensive as a Field or Tjernland. Another benefit is the fan noise away from the boiler.0
