Buderus G115 Model 28
RoosterBoy
RoosterBoy Member Posts: 459
hi I have the g115 model 28 and air handler how long should the boiler take when it is all tuned right to heat my air handler to 180deg right now it's 10 to 12 mins from
cold
thanks
  • dconnors
    dconnors Member Posts: 215
    G115/28
    It all depends on your setup. If you call in the circ once the boiler is hot, it will shorten your heat up time. If you have our control it would be best to call us to help you with this problem.
  • RoosterBoy
    what is better to heat the boiler to 180 then turn on circulator or to always run circulator
    thanks
