help with a Burnham part
The # 2M890 kit that is shown in their catalog probably does include the rear target wall and the burner mounting plate insulation, based on the price. If you want to order the original Burner Mounting Plate Insulation, the Burnham part # is # 8202210. The V14A was also equipped with a chamber liner on the bottom of the chamber. The part number for that is # 82022043. Both are readily available from Lancaster, PA. Hope this helps.
Glenn Stanton
Burnham Hydronics
  • RonE
    RonE Member Posts: 29
    need help with a Burnham
    I replaced a Burnham V 14 block assy today. it had a target wall... but I need the "form fitting" gasket/heat shield that fits in back of the burner/inspection plate. I see a target wall listed in my RE Michels cat. my question is does this part come with the target wall. best discription I can give is it is "hour glass" shaped. If so I will have RE michel bring one in, they had one in stock (about 80 miles from me) I used a wet pack and a lynn head protecter for a temp fix.
    Ron
  • RonE
    Thanks for the info. The saturday help at the Annopolis Md branch left a little to be desired. I will stop by the Baltimore branch mon and pick up the 2m890. The RE Michels warehouse will have one. Again many thanks for the quick reply.
