News from B&G
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,643
Morton Grove, IL, October 28, 2004 - Bell & Gossett" has introduced new Valve Installation Kits that help improve HVAC system operating performance, as well as save time for engineers and installers in the field.
Sixteen standard Valve Kits provide hundreds of installation combinations. Bell & Gossett's Circuit SentryT and Circuit Setter Plus® balancing products are available with several of the kit models to provide system functionality and integrated ports for accessory devices such as pressure and temperature measurement ports, air vent or drain valves.
The Valve Installation Kits include options for flexible braided metal hoses and pipe run out sizes from 1/2" to 3". The kits also allow for a variety of packaging and tagging options.
Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, circulators, hydronic specialties, heat exchangers, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.
  • mark_40
    mark_40 Member Posts: 65
    Dan ....
    would this new stuff be U.S. made ... or ... made in Chinka, like the 3" air seperator i just unboxed ... i can't belive they would do THAT !
  • DanHolohan
    Beats me.
    It was a press release. They emailed it and I posted it.
  • mark_40
    ya know ...
    i have specified B&G fo 20 years ... been able to feel good about it all being American made .....i'm suspecting all the new products are imports ... my air seperator, Guard-Doggys ..... bummer ....
  • DanHolohan
    How's
    the quality looking?
  • mark_40
    I.A.S.
    was ...... nice ! .. clean , sharp threads ..nice casting ....Guard-Doggys ... lotta failures ........Now whadda i do tho ... i quit specifying the green brand , 'cause of the import castings .... do i have to go with Brand "A" ???
  • hr
    hr Member Posts: 6,106
    B&Gs
    largest foundry is in India, another in China. Good chance all the cast products will be from overseas soon, if not already. I suspect.
    I notice Brazil and Mexico stamped on Taco products also.
    Foundries and other "dirty" industries go over seas for pollution reasons among others. Doubt that you will ever see this type of industry return.
    It's a global economy, if the quality is as good or better, so be it.
    Pretty much all the condensing boiler equipment comes from overseas, regardless of the name on the jacket.
    hot rod
