Just wrapped up the Buderus install.
Ted_9
Ted_9 Member Posts: 1,718
Uni, thats funny because I have on on the truck that I use. I guess I forgot when then electricians ask whick zone was what, I just used a marker.
J.C.A., its amazingly quiet.
PATRIOT HEATING & COOLING, INC.
  • Ted_9
    This is a GA124/23 with a Logomatic R2107 and an ST150 indirect hot water heater. Three copper fin tube zones and one zone for the indirect using the Logomatic priority.
    I'm very impressed at what little noise this unit makes. You basically cant even here it running. The circulators are louder than the boiler. If I can get the Buderus Wall mount condensing unit soon, I'm puting a GA124 in my house.
  • Uni R
    Uni R Member Posts: 663
    Labelling
    www.dymo.com
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Ted,
    I agree with the quiet part. My Bacarach tester was louder than the running boiler. I had to look through the port to make sure it was running when I lit off my first one. Makes the customer very happy too! Chris
  • Joe@buderus
    Joe@buderus Member Posts: 165
    Install
    Thanks for the pictures. The GA124 Boiler is indeed very, very quiet!
