Sucking Air
Ted_9
Member Posts: 1,718
Just saw this today. I'm proposing radiant heat in the addition, den area.
When I mentioned that this piping arangement is not optimal and that the system could get air in it, they said, "yes, It does every year."
Can you guess what I told them next?
BTW the boiler is a year or two old, so no, I didnt say replace the boiler.
PATRIOT HEATING & COOLING, INC.
(snicker) ... they finally called the Right contractor !0 -
wow
with all that room why stuff it in two inchs? Incredible the thing's you see.....Have fun with that one...:)0 -
They couldn't
get those circulators any closer together?
David0 -
Circulators having
a circle jerk!!!0 -
Whats funny is that the guy that installed this is probably proud of himself.
PATRIOT HEATING & COOLING, INC.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
