Sucking Air
Ted_9
Member Posts: 1,718
Just saw this today. I'm proposing radiant heat in the addition, den area.
When I mentioned that this piping arangement is not optimal and that the system could get air in it, they said, "yes, It does every year."
Can you guess what I told them next?
BTW the boiler is a year or two old, so no, I didnt say replace the boiler.
PATRIOT HEATING & COOLING, INC.
(snicker) ... they finally called the Right contractor !0 -
wow
with all that room why stuff it in two inchs? Incredible the thing's you see.....Have fun with that one...:)0 -
They couldn't
get those circulators any closer together?
David0 -
Circulators having
a circle jerk!!!0 -
Whats funny is that the guy that installed this is probably proud of himself.
PATRIOT HEATING & COOLING, INC.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
