Towel warmers
Terry Larsell
Member Posts: 54
How would a towel warmer work hooked into a slab temp loop with outdoor reset? I was thinking of offering them as a future add on for the non radiant upper floor but I don't really want to add another temp also. Has anyone tried this? Temp would vary between 85 to 110.
Terry
Terry
Towel warmers
They work very well.The output is less than if they are on a high temperature loop but still do an effective job.0 -
keep in mind
Towel warmers are to warm towels not to heat a room. They lose effectiveness when covered with towels. Even at low temps they will warm your towels though.0 -
I like to keep towel warmers to at the vary least a few degrees over body temperature.
Ron0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
