Correct Size of Header for Boiler
Bruce M.
Member Posts: 143
I am planning to install a new oil fired boiler that has a 1-1/2" supply and 1-1/2" return. There are 3 zones of baseboard which are all piped with 3/4" copper tubing. I have been looking at prefabricated headers and I would like to know the proper size header that should be used. Thank you for any information.
Correct Sizing of Header for Boiler
I am planning to install a new oil fired boiler that has a 1-1/2" supply and 1-1/2" return. There are 3 zones of baseboard which are all piped with 3/4" copper tubing. I have been looking at prefabricated headers and I would like to know the proper size header that should be used. Thank you for any information.0 -
is this a real question?0 -
when you did...
the heat loss what were the numbers? What are the break down for each zone? What boiler is it? kpc
- 167 Indoor-Air Quality
