protek valve in oil burner nozzle
KMD
Member Posts: 10
any of you guys ever use these valves do they work as they are suppose to?
www.delavaninc.com/pdf/pro-tek.pdf
Great idea, and it works!
Looks like a good idea and I've always liked Delavan but the "C" & "D" illustration on their site is showing a pretty
large stream of after drip. I'd tend to look for a very bad
pump PRV with that much oil coming out at shut down. Little more than a 20% drop in that photo.
pump cut off with that much oil coming out at shut down. Little more than a 20% drop in that photo. I am a little disappointed the more I look at it. They are claiming that
standard nozzles can't prevent the after drip shown in the photos.(E&F) I wouldn't turn to a nozzle to correct that level of after drip. I've seen some clean cut off with standard nozzles.
BB0 -
Looks like a great idea if it works.
Wonder how long they will last before the spring breaks? I have never used them. Anyone have any track record on these?
I know a number of places I would love to install these instead of oil delay vlvs.
Agree that the pictures are not the best comparision. Must be one old worn out pump cut-off, and maybe a little head pressure from the fuel tank?
Steve0 -
It's not to replace an
oil valve, but rather to work in conjunction with one, no leaks, positive cutoff, that's the goal!0 -
pressure on nozzle
oil valve and check at nozzle?hmmmm doesn't that create a closed loop that may increase in pressure with heat?just wondering aloud, I'll have to try some experimenting with my burner.0
