Taco RMB?
Andy_14
Member Posts: 121
In a single zone closed system with aprox. 2500' 1/2 pex all loops less than 300'. Will the taco RMB circulate this system by itself or will I need another circ. pump?
well, it is going to depend upon the heat loss of the structure
if for example i had a 2500 sq ft tent it would not preform the identical same way r-24 walls ,R-48+ ceilings,low _E windows with few fenatration issues surrounded on three sides by hills with south facing glazing for example,there are a few variables in the equasion. is the ability to pump ice a requirement? glycol? how thick a slab ?is it insulated? what you may need is a bit of a blowerdoor test.because iam fairly certain it wont pump ice. adding water to an existing slab with out determining some of these variables can lead you into trouble real quick.0 -
Est. heat loss on design day(-10deg) is 60K btu's/hr. This is new construction and is not yet done, so a blowerdoor test is not an option. I'm just trying to figure out the best way to put together the system.0
- 167 Indoor-Air Quality
