smith boiler
lchmb
Member Posts: 2,997
Have any information on the smith 18-5 cast iron boiler? This unit is fired with a Carlin 102crd. Looking for lowest gph and draft readings. Also what the unit normally run's for a stack temp...:) thanks..
Posted answer on OTT first!
Thank you
- 167 Indoor-Air Quality
