\"McKeesport\"
Dave Bush
Member Posts: 155
This is the only marking on it.
Is this the MFG, or is it possibly just a reference to the town in PA that was home to many steel mills/foundries.
Any info would be appreciated. We're replacing the old bouiler and this one rad is the only one I couldn't find a rating for...
Don't see it in the EDR book or library here.
McKeesport
As I used to work for U.S.Steel, I can tell you that there was a McKeesport Foundry in McKeesport, Pa., which is a close suburb of Pittsburgh. Unknown if they made your radiator. I'm sure they are long gone.0 -
Thanks, Ken.
Looks a lot like a Weil-McLain Cameo, but is stamped for McKeesport. I'm pretty certain that we measured it right, and we came close when compared to the WM's in the EDR book...
- 167 Indoor-Air Quality
