Pipe Attachments
Mike T., Swampeast MO
Member Posts: 6,928
Anyone know of single straps/clamps that will stand off from a wall (brick) about 1"? Need in ½", ¾" and 1" (black iron) sizes.
Local supply house only has big elaborate bar systems--expensive overkill for this app.--but figured someone here would know of something a bit "prettier" than wood blocks.
Thanks!
Thanks!
I believe.......
I think Souix Chief makes what you want. Not sure who carries their product.0 -
Local house carries Sioux Chief products but not that one. Will try to look up. THANKS!0 -
Mike-
This may be pedestrian, but I use Fee and Mason plates and split rings with 3/8" threaded rod and large 3/8" nuts for stiffness. I can go off a wall about 3 inches or more depending on pipe size. My whole hot water distribution "wall" is set up this way. (I was in a hurry and could not wait for Unitstrut.)
But I will check out the Sioux Chief line before the PC crowd makes them change their name!0 -
Mupro
Try Mupro...they ship UPS and the catalogue is online. I have the threaded rod cutter and stock the split ring hangers to supplement the B-Line cush-clamps
www.muprousa.com
what is the trade price for the rod cutter,Paul. it lists for close to three big ones.0 -
you could use a mineralck(emt standoffs) clamp with long tapcon and pc of small spacer0 -
Price
I believe trade price is slightly over $200. Ask Leo for the ISH special price!
Ever hear of a product called Valley Hangers? Available in all sizes 3/8 copper to 2 IPS Epoxy coated with 2 hole mounting0
- 167 Indoor-Air Quality
