Electric HW: tank or tankless?
Patchogue Phil_26
Member Posts: 3
Friend lives in an all electric development in Plano TX. No nat gas, no LPG, no oil. Old, short stubby water heater under the stairs is showing it's age (9yrs). I think it is the original builder installed.
Given the height requirements and a desire for efficient and long lasting, what would be better: another electric tank or an electric tankless?
I figure the tankless would have no standby losses but I have no idea on operating costs as compared to a tank. Nor of which costs more to buy/install. Nor of longevity.
The home is 2 bath, 1 kitchen, laundry. Existing tank of 40 gallons. 1 person occupancy.
Any recommendations?
Depends somewhat
on the amount of HW they need. More importantly how much they need at what rate. Smaller tankless probably peak out at 2-3gpm.
Can't imagine the incoming water temperature gets real cold in Texas? That's a consideration when sizing.
You may need more than a typical 30 amp 240V circuit to drive one, however. Any way to upsize the circuit easily?
hot rod
tankless
> Can't
> sizing.
> hot rod
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 144&Step=30"_To Learn More About This
> "Find A Professional"_/A_
tankless wire size
Good point about the existing wiring limitations. I have not seen the house, just talking with my friend and it came up in conversation that the water heater was acting up, might need replacing and I was asked if I could recommend a good brand or features to consider. I am just thinking out loud about *maybe* a tankless would be a good replacement given the usual small selection of large capacity short stubby electric tanks.
The house is in one of those newer developments north-east of DFW. Not too cold in winter (lowest low typically 40* +/-). But wouldn't underground temp still be around 55* +/- typically down there the same as in NY/NJ?
I am sure everything is finished with drywall in and around the elec panel and garage. I've seen other of these cookie-cutter type developments in DFW area. Running heavier wire would add much to the cost.
Thanks for your input.0 -
Forget elec tankless
Gas tankless units can product over 100K of heat to instantly heat water. Electric units can use up to 80 to 90 AMPS of power for a residental size unit. Many only offer 1/2" piping. The electric WH works well since the slower/lower amp heating elements heat up a buffer of water over a longer period. They all have a life span of only 10 yrs. Maybe just try to find a 50 gal low-boy (tough) if they're running out of hot water.0 -
This 14 KW
Seisco uses two seperate 30 amp circuits to power it. About 1.5 gpm at 69° rise. Enough for a low flow shower head
Fun to watch it modulate the current draw as it runs up to temperature.
Made in Texas, too!
I didn't have much luck using it on a small radiant though.
hot rod
Actually made just
south of Texas
hot rod
- 167 Indoor-Air Quality
