Which boiler would you suggest??????
Brian_15
Brian_15 Member Posts: 3
I Have a house that has pex tubing in the basement and onix tubing for a staple-up application, there is going to be a/c and secondary heat, looking for suggestions on a air handler or a forced or (scorched air) furnace, and which boiler would be a better choice on reliabilty and efficiency, Weil Mclain Ultra, Utica UB90, Viessmann Vitoden, or any other suggestion would be nice, would like to hear pros and cons of reliabilty of any of these condensing boilers, would a crown CSC (83-84%)do just as well with a Tekmar outdoor reset and injection package, there will be a 50 gallon water maker on the system, Thanks for any feedback Brian
  • lchmb
    lchmb Member Posts: 2,997
    .02 cents
    I would suggest you check with local supplier's and installer's. I say this because I may find a boiler to be the best, based on support, supplies and personal preference. Someone in another state will tell you I am crazy because he's never gotton support or spend's 3 month's getting part's.....I think you need what is best in your area...:) good luck...
